I have been reading the docs but I’m still missing some critical info about the way that Loki stores/uses data, as I have been having problems with my main storage that started being full randomly. I have it deployed via Helm chart.
This is my (fairly summarized) values.yaml file I’m using, in case it’s helpful:
compactor:
working_directory: /var/loki/data/retention
compaction_interval: 10m
retention_enabled: true
retention_delete_delay: 2h
retention_delete_worker_count: 150
delete_request_store: s3
ingester:
chunk_block_size: 262144
chunk_retain_period: 1m
chunk_target_size: 1572864 # 1.5MB
chunk_encoding: snappy
max_chunk_age: 2h
chunk_idle_period: 1h
lifecycler:
final_sleep: 0s
ring:
replication_factor: 1
heartbeat_timeout: 10m
persistence:
enabled: true
limits_config:
retention_period: 30d
ingestion_rate_mb: 8
ingestion_burst_size_mb: 16
per_stream_rate_limit: 5MB
per_stream_rate_limit_burst: 15MB
tsdb_max_query_parallelism: 128
split_queries_by_interval: 1h
commonConfig:
path_prefix: /var/loki
replication_factor: 3
compactor_address: '{{ include "loki.compactorAddress" . }}'
storage:
bucketNames:
chunks: loki-boltdb
ruler: loki-boltdb
type: s3
s3:
endpoint: ...
filesystem:
chunks_directory: /var/loki/chunks
rules_directory: /var/loki/rules
I’d like to understand why sometimes the df usage spikes quite a bit. This is the output right now:
/ $ du -hs /var/loki
1.1G /var/loki
/ $ df -h /var/loki
Filesystem Size Used Available Use% Mounted on
/dev/zzz 29.2G 1.5G 27.7G 4% /var/loki
But I’ve seen it go to 100% and indeed there was little usage from the du command. This is due to opened files from Loki that are already removed. Under these circumstances, we commonly reboot and the problem goes away.
Is this a bug from Loki, or is any config perhaps conflicting from my side?
I don’t use filesystem with Loki, so I am not really sure what’s happening. Couple of questions:
- Are you running du / df from inside your container? Have you tried using
lsof to see what’s hanging onto the file descriptors?
- Not sure why
replication_factor is set to 3 when you have only one Loki instance.
- Might consider disabling WAL if you are storing Loki data in filesystem.
Hi @tonyswumac , thanks for helping me out
Yes, I’m running du / df from inside the container.
I used lsof +L1 and currently it’s mostly TSDB files under /var/loki/tsdb-shipper-cache/ (although there is one descriptor related to WAL /var/loki/wal/checkpoint.053812.tmp/00000000 which is right now occupying 70MB), but I plan to check when the next big spike appears again
I’m using 2 instances of Loki. What do you recommend?
Is it? I don’t really know what’s the ingester actually doing, it’s not clear to me as per the docs. I thought it was sending everything to S3, and that WAL is important because otherwise I lose data which is still in memory if I reboot the pod.
How do you leave out the filesystem with Loki? What do you refer to apart from disabling WAL? I wouldn’t like to lose any log (At least, let’s say, more than 1min worth of logs)
EDIT: I will share the full values.yaml file here so you could help me out better then:
deploymentMode: SingleBinary
loki:
image:
tag: 3.1.0
config: |
{{- if .Values.enterprise.enabled}}
{{- tpl .Values.enterprise.config . }}
{{- else }}
auth_enabled: {{ .Values.loki.auth_enabled }}
{{- end }}
{{- with .Values.loki.server }}
server:
{{- toYaml . | nindent 2}}
{{- end}}
pattern_ingester:
enabled: {{ .Values.loki.pattern_ingester.enabled }}
memberlist:
{{- if .Values.loki.memberlistConfig }}
{{- toYaml .Values.loki.memberlistConfig | nindent 2 }}
{{- else }}
{{- if .Values.loki.extraMemberlistConfig}}
{{- toYaml .Values.loki.extraMemberlistConfig | nindent 2}}
{{- end }}
join_members:
- {{ include "loki.memberlist" . }}
{{- with .Values.migrate.fromDistributed }}
{{- if .enabled }}
- {{ .memberlistService }}
{{- end }}
{{- end }}
{{- end }}
{{- with .Values.loki.ingester }}
ingester:
{{- tpl (. | toYaml) $ | nindent 4 }}
{{- end }}
{{- if .Values.loki.commonConfig}}
common:
{{- toYaml .Values.loki.commonConfig | nindent 2}}
storage:
{{- include "loki.commonStorageConfig" . | nindent 4}}
{{- end}}
{{- with .Values.loki.limits_config }}
limits_config:
{{- end }}
runtime_config:
file: /etc/loki/runtime-config/runtime-config.yaml
{{- with .Values.chunksCache }}
{{- if .enabled }}
chunk_store_config:
chunk_cache_config:
default_validity: {{ .defaultValidity }}
background:
writeback_goroutines: {{ .writebackParallelism }}
writeback_buffer: {{ .writebackBuffer }}
writeback_size_limit: {{ .writebackSizeLimit }}
memcached:
batch_size: {{ .batchSize }}
parallelism: {{ .parallelism }}
memcached_client:
addresses: dnssrvnoa+_memcached-client._tcp.{{ template "loki.fullname" $ }}-chunks-cache.{{ $.Release.Namespace }}.svc
consistent_hash: true
timeout: {{ .timeout }}
max_idle_conns: 72
{{- end }}
{{- end }}
{{- if .Values.loki.schemaConfig }}
schema_config:
{{- toYaml .Values.loki.schemaConfig | nindent 2}}
{{- end }}
{{- if .Values.loki.useTestSchema }}
schema_config:
{{- toYaml .Values.loki.testSchemaConfig | nindent 2}}
{{- end }}
{{ include "loki.rulerConfig" . }}
{{- if or .Values.tableManager.retention_deletes_enabled .Values.tableManager.retention_period }}
table_manager:
retention_deletes_enabled: {{ .Values.tableManager.retention_deletes_enabled }}
retention_period: {{ .Values.tableManager.retention_period }}
{{- end }}
query_range:
align_queries_with_step: true
{{- with .Values.loki.query_range }}
{{- tpl (. | toYaml) $ | nindent 2 }}
{{- end }}
{{- if .Values.resultsCache.enabled }}
{{- with .Values.resultsCache }}
cache_results: true
results_cache:
cache:
background:
memcached_client:
addresses: dnssrvnoa+_memcached-client._tcp.{{ template "loki.fullname" $ }}-results-cache.{{ $.Release.Namespace }}.svc
update_interval: 1m
{{- end }}
{{- end }}
{{- with .Values.loki.storage_config }}
storage_config:
{{- end }}
{{- with .Values.loki.query_scheduler }}
query_scheduler:
{{- end }}
{{- with .Values.loki.compactor }}
compactor:
{{- end }}
{{- with .Values.loki.analytics }}
analytics:
{{- end }}
{{- with .Values.loki.querier }}
querier:
{{- end }}
{{- with .Values.loki.index_gateway }}
index_gateway:
{{- end }}
{{- with .Values.loki.frontend }}
frontend:
{{- end }}
{{- with .Values.loki.frontend_worker }}
frontend_worker:
{{- end }}
{{- with .Values.loki.distributor }}
distributor:
{{- end }}
tracing:
enabled: {{ .Values.loki.tracing.enabled }}
auth_enabled: false
server:
http_listen_port: 3100
grpc_listen_port: 9095
grpc_server_max_recv_msg_size: 52434304 # 50MBi
grpc_server_max_send_msg_size: 52434304 # 50MBi
limits_config:
commonConfig:
storage:
bucketNames:
chunks: loki-boltdb
ruler: loki-boltdb
type: s3
s3:
endpoint: ...
region: ...
secretAccessKey: ${S3_SECRET_ACCESS_KEY}
accessKeyId: ${S3_ACCESS_KEY_ID}
s3ForcePathStyle: true
sse_encryption: false
insecure: false
http_config:
idle_conn_timeout: 90s
response_header_timeout: 0s
insecure_skip_verify: true
filesystem:
schemaConfig:
configs:
store: tsdb
object_store: s3
schema: v13
index:
prefix: index_
period: 24h
store: tsdb
object_store: s3
schema: v13
index:
prefix: index_
period: 24h
query_scheduler:
max_outstanding_requests_per_tenant: 2048
storage_config:
hedging:
at: "250ms"
max_per_second: 20
up_to: 3
compactor:
pattern_ingester:
enabled: false
querier:
max_concurrent: 8
ingester:
max_chunk_age: 2h
lifecycler:
final_sleep: 0s
ring:
frontend:
scheduler_address: '{{ include "loki.querySchedulerAddress" . }}'
log_queries_longer_than: 20s
frontend_worker:
ingress:
enabled: false
test:
enabled: false
lokiCanary:
enabled: false
singleBinary:
replicas: 2
extraArgs:
- -config.expand-env=true
extraEnv:
- name: S3_ACCESS_KEY_ID
valueFrom:
secretKeyRef:
key: AWS_ACCESS_KEY_ID
- name: S3_SECRET_ACCESS_KEY
valueFrom:
secretKeyRef:
key: AWS_SECRET_ACCESS_KEY
resources:
limits:
cpu: "5"
memory: 8Gi
requests:
cpu: 200m
memory: 3Gi
persistence:
enabled: true
enableStatefulSetAutoDeletePVC: false
write:
replicas: 0
read:
replicas: 0
backend:
replicas: 0
resultsCache:
enabled: true
replicas: 2
chunksCache:
enabled: true
replicas: 2
gateway:
enabled: false
loki:
limits_config:
retention_stream:
- selector: '{app="..."}'
priority: 1
period: 7d
(I have the values.yaml scattered over multiple files, I pasted it altogether, apologies in case that creates some confusion)
Thank you
I don’t see anything obviously wrong with the configuration. I’d say if you can confirm that your chunks are written to S3, and that you aren’t running out of space in your persistent volume for WAL, you should be good.
I wouldn’t be too concerned about differences between du and dh. They calculate blocks differently, I don’t remember the details, but I am sure Google can tell you.
I updated to 100GB, so let’s see if giving it more room fixes this excepcionally transient issue. Thanks for reviewing my config.
FYI: The difference between du and df (I wrote dh in the title but it’s actually df) becomes noticeable whenever there is a deleted file that is still opened by a process, so almost at all times there are files under the WAL and TSDB directories that are already deleted, but for Loki the file descriptor is still open, and du shows the size of it. I suspect this is causing the filling-ups of the disks.
I honestly haven’t run into this. Our write Loki targets on average stays alive for 100 days (refreshed whenever we refresh the cluster nodes), and I’ve never seen this. If you install and run lsof in your Loki container you might be able to find out what’s holding it up.
Some additional info.
~ ❯ k exec -it loki-stack-1 -c loki -- df -h
overlay 874.7G 355.4G 474.8G 43% /
tmpfs 64.0M 0 64.0M 0% /dev
/dev/mapper/vg0-root 874.7G 355.4G 474.8G 43% /tmp
/dev/mapper/vg0-root 874.7G 355.4G 474.8G 43% /rules
/dev/rbd19 98.1G 33.9G 64.2G 35% /var/loki
/dev/mapper/vg0-root 874.7G 355.4G 474.8G 43% /etc/hosts
/dev/mapper/vg0-root 874.7G 355.4G 474.8G 43% /dev/termination-log
/dev/mapper/vg0-root 874.7G 355.4G 474.8G 43% /etc/hostname
/dev/mapper/vg0-root 874.7G 355.4G 474.8G 43% /etc/resolv.conf
shm 64.0M 0 64.0M 0% /dev/shm
/dev/mapper/vg0-root 874.7G 355.4G 474.8G 43% /etc/loki/config
/dev/mapper/vg0-root 874.7G 355.4G 474.8G 43% /etc/loki/runtime-config
tmpfs 503.2G 12.0K 503.2G 0% /run/secrets/kubernetes.io/serviceaccount
tmpfs 251.6G 0 251.6G 0% /proc/acpi
tmpfs 64.0M 0 64.0M 0% /proc/kcore
tmpfs 64.0M 0 64.0M 0% /proc/keys
tmpfs 64.0M 0 64.0M 0% /proc/timer_list
tmpfs 251.6G 0 251.6G 0% /proc/scsi
tmpfs 251.6G 0 251.6G 0% /sys/firmware
and:
~ ❯ k exec -it loki-stack-1 -c loki -- du -hs /var/loki
735.5M /var/loki
And as I shared in past comments, this is mostly coming from tsdb-shipper-cache or the WAL:
~ ❯ k exec -it loki-stack-1 -c loki -- lsof +L1
1 /usr/bin/loki 0 /dev/null
1 /usr/bin/loki 1 pipe:[1930131713]
1 /usr/bin/loki 2 pipe:[1930131714]
1 /usr/bin/loki 3 socket:[1929276169]
1 /usr/bin/loki 4 anon_inode:[eventpoll]
1 /usr/bin/loki 5 pipe:[1929426731]
1 /usr/bin/loki 6 pipe:[1929426731]
1 /usr/bin/loki 7 socket:[1929276173]
1 /usr/bin/loki 8 socket:[3945572279]
1 /usr/bin/loki 9 socket:[1930121098]
1 /usr/bin/loki 10 /var/loki/data/retention/deletion/delete_requests/delete_requests
1 /usr/bin/loki 11 socket:[3947680960]
1 /usr/bin/loki 12 socket:[3927301334]
1 /usr/bin/loki 13 socket:[3819566135]
1 /usr/bin/loki 14 socket:[218707]
1 /usr/bin/loki 15 socket:[3947682238]
1 /usr/bin/loki 16 socket:[3944805681]
1 /usr/bin/loki 17 socket:[3842777244]
1 /usr/bin/loki 19 socket:[3823830383]
1 /usr/bin/loki 20 socket:[360997018]
1 /usr/bin/loki 21 socket:[360997045]
1 /usr/bin/loki 22 /var/loki/tsdb-shipper-active/multitenant/index_20039/1731403822-loki-stack-1-1729494248949849743.tsdb
1 /usr/bin/loki 23 socket:[3945093985]
1 /usr/bin/loki 25 socket:[736276]
1 /usr/bin/loki 27 socket:[125559117]
1 /usr/bin/loki 28 /var/loki/tsdb-shipper-active/wal/s3_2024-04-16/1731404722/00000000
1 /usr/bin/loki 29 socket:[3946923576]
1 /usr/bin/loki 30 socket:[3818084939]
1 /usr/bin/loki 31 socket:[3930553114]
1 /usr/bin/loki 32 socket:[2930171631]
1 /usr/bin/loki 34 socket:[1928701746]
1 /usr/bin/loki 35 socket:[3946815975]
1 /usr/bin/loki 36 socket:[2077132112]
1 /usr/bin/loki 39 socket:[1931556898]
1 /usr/bin/loki 40 socket:[1928677289]
1 /usr/bin/loki 41 socket:[360997019]
1 /usr/bin/loki 42 /var/loki/tsdb-shipper-active/wal/s3_2024-09-24/1731404722/00000000
1 /usr/bin/loki 43 socket:[3819522947]
1 /usr/bin/loki 44 socket:[1930240870]
1 /usr/bin/loki 45 socket:[1929405119]
1 /usr/bin/loki 46 socket:[1930109396]
1 /usr/bin/loki 47 socket:[1930862925]
1 /usr/bin/loki 48 socket:[1929597839]
1 /usr/bin/loki 49 socket:[1931219998]
1 /usr/bin/loki 50 socket:[3927626286]
1 /usr/bin/loki 51 socket:[3944109364]
1 /usr/bin/loki 52 socket:[1929529069]
1 /usr/bin/loki 53 socket:[1931220009]
1 /usr/bin/loki 54 socket:[1928678204]
1 /usr/bin/loki 55 socket:[1931556943]
1 /usr/bin/loki 56 socket:[1930498351]
1 /usr/bin/loki 57 socket:[1930884667]
1 /usr/bin/loki 58 socket:[1929401296]
1 /usr/bin/loki 59 socket:[1930139269]
1 /usr/bin/loki 60 socket:[1930835212]
1 /usr/bin/loki 61 socket:[1930496833]
1 /usr/bin/loki 62 socket:[1931220303]
1 /usr/bin/loki 63 socket:[3821067910]
1 /usr/bin/loki 64 socket:[1991872741]
1 /usr/bin/loki 69 socket:[1991136982]
1 /usr/bin/loki 70 socket:[3941884916]
1 /usr/bin/loki 71 socket:[3928354402]
1 /usr/bin/loki 72 /var/loki/tsdb-shipper-cache/index_20039/fake/1731404139939417407-compactor-1731356607217-1731403812832-90a5bb0a.tsdb
1 /usr/bin/loki 74 socket:[359547452]
1 /usr/bin/loki 82 /var/loki/tsdb-shipper-cache/index_20039/1731403817-loki-stack-0-1728284179805865181.tsdb
1 /usr/bin/loki 83 /var/loki/tsdb-shipper-cache/index_20039/1731403822-loki-stack-1-1729494248949849743.tsdb
1 /usr/bin/loki 84 /var/loki/wal/00006414
1 /usr/bin/loki 85 /var/loki/wal/checkpoint.006413.tmp/00000000
1 /usr/bin/loki 452 socket:[3822514858]
I really think this should be something the developers should look into. Already deleted files which are still opened in Loki is a waste of storage resources. And this is always growing up, so it end ups corrupting the storage, or in the best case simply stopping loki. Why do I have to have a 100GB volume (per loki replica) when it’s only really needed 2GB or so? And why do I need it to restart the STS manually from time to time so that it doesn’t cross this 100GB limit?
In your lsof command I see 6 lines for shipper-cache, which one of those are files already deleted?
I just double checked again, on our writer container that’s been up for 80-ish days I don’t see any open file descriptors from Loki pointing to a file that no longer exists.
Let me show you more data as of now (last night there was a restart, so currently I can only show the inconsistency of the last 5h (which is a small difference, but it still is):
~ ❯ k exec -it loki-stack-0 -c loki -- df -h
/dev/rbd16 98.2G 957.9M 97.3G 1% /var/loki
~ ❯ k exec -it loki-stack-0 -c loki -- du -hs /var/loki
248.6M /var/loki
1 /usr/bin/loki 46 /var/loki/tsdb-shipper-active/wal/s3_2024-09-24/1731492032/00000000
1 /usr/bin/loki 47 /var/loki/tsdb-shipper-active/multitenant/index_20040/1731491132-loki-stack-1-1713781691510093445.tsdb
1 /usr/bin/loki 49 /var/loki/wal/00061563
1 /usr/bin/loki 53 /var/loki/tsdb-shipper-cache/index_20040/fake/1731492263966231020-compactor-1731447411558-1731492014228-c6513adb.tsdb
1 /usr/bin/loki 57 /var/loki/wal/checkpoint.061562.tmp/00000000
1 /usr/bin/loki 64 /var/loki/tsdb-shipper-active/wal/s3_2024-04-16/1731492032/00000000
1 /usr/bin/loki 93 /var/loki/tsdb-shipper-cache/index_20039/fake/1731474261618529089-compactor-1731339288343-1731465277302-8833e692.tsdb
For each one:
~ ❯ k exec -it loki-stack-1 -c loki -- ls -lash /var/loki/data/retention/deletion/delete_requests/delete_requests
16.0K -rw-rw-r-- 1 loki loki 16.0K May 7 2024 /var/loki/data/retention/deletion/delete_requests/delete_requests
~ ❯ k exec -it loki-stack-1 -c loki -- ls -lash /var/loki/tsdb-shipper-active/wal/s3_2024-09-24/1731492032/00000000
80.0K -rw-r--r-- 1 loki loki 75.6K Nov 13 10:15 /var/loki/tsdb-shipper-active/wal/s3_2024-09-24/1731492032/00000000
~ ❯ k exec -it loki-stack-1 -c loki -- ls -lash /var/loki/tsdb-shipper-active/multitenant/index_20040/1731491132-loki-stack-1-1713781691510093445.tsdb
128.0K -rw-r--r-- 1 loki loki 127.5K Nov 13 10:00 /var/loki/tsdb-shipper-active/multitenant/index_20040/1731491132-loki-stack-1-1713781691510093445.tsdb
~ ❯ k exec -it loki-stack-1 -c loki -- ls -lash /var/loki/wal/00061563
159.6M -rw-r--r-- 1 loki loki 159.6M Nov 13 10:14 /var/loki/wal/00061563
~ ❯ k exec -it loki-stack-1 -c loki -- ls -lash /var/loki/tsdb-shipper-cache/index_20040/fake/1731492263966231020-compactor-1731447411558-1731492014228-c6513adb.tsdb
7.1M -rw-r--r-- 1 loki loki 7.1M Nov 13 10:04 /var/loki/tsdb-shipper-cache/index_20040/fake/1731492263966231020-compactor-1731447411558-1731492014228-c6513adb.tsdb
~ ❯ k exec -it loki-stack-1 -c loki -- ls -lash /var/loki/wal/checkpoint.061562.tmp/00000000
ls: /var/loki/wal/checkpoint.061562.tmp/00000000: No such file or directory
command terminated with exit code 1
~ ❯ k exec -it loki-stack-1 -c loki -- ls -lash /var/loki/tsdb-shipper-active/wal/s3_2024-04-16/1731492032/00000000
ls: /var/loki/tsdb-shipper-active/wal/s3_2024-04-16/1731492032/00000000: No such file or directory
~ ❯ k exec -it loki-stack-1 -c loki -- ls -lash /var/loki/tsdb-shipper-cache/index_20039/fake/1731474261618529089-compactor-1731339288343-1731465277302-8833e692.tsdb
16.4M -rw-r--r-- 1 loki loki 16.4M Nov 13 08:04 /var/loki/tsdb-shipper-cache/index_20039/fake/1731474261618529089-compactor-1731339288343-1731465277302-8833e692.tsdb
I am not sure what’s happening with your cluster, I can only say that WAL going full has never been a problem for us (4 writer, 50GB each for WAL). Perhaps try opening a bug request in Github.
I’ll say it may be useful to include the same data as your latest reply (lsof + individual ls to verify if file exists) when your WAL disk is almost full. It would be interesting to see how many file handlers are being left open.
Hi all,
I’m facing the same issue. du is showing ~137M but df ~887M
I’m storing data on azure, but the last 24 hours on local for fast response.
Maybe it’s something wrong in my values?
loki:
auth_enabled: false
storage:
bucketNames:
chunks: loki
ruler: loki
admin: loki
type: azure
azure:
accountName: xxxxxxxxxxxx
useManagedIdentity: true
useFederatedToken: false
userAssignedId: "xxxxxxxxxxxx"
compactor:
working_directory: /var/loki/data/boltdb-shipper-compactor
storage_config:
boltdb_shipper:
active_index_directory: /var/loki/data/boltdb-shipper-active
cache_location: /var/loki/data/boltdb-shipper-cache
cache_ttl: 24h
tsdb_shipper:
active_index_directory: /var/loki/data/tsdb-index
cache_location: /var/loki/data/tsdb-cache
filesystem:
directory: /var/loki/data/chunks
schemaConfig:
configs:
index:
period: 24h
prefix: index_
object_store: azure
schema: v11
store: boltdb-shipper
index:
prefix: index_
period: 24h
object_store: azure
schema: v13
store: tsdb
ingester:
chunk_block_size: 3145728 # 3mb - The targeted _uncompressed_ size in bytes of a chunk block
max_chunk_age: 24h
chunk_idle_period: 60m
chunk_retain_period: 30m
chunk_target_size: 524288 # 0.5mb - The targeted _uncompressed_ size in bytes of a chunk block
commonConfig:
limits_config:
max_concurrent_tail_requests: 100
split_queries_by_interval: 24h
max_query_parallelism: 100
reject_old_samples: true
ingestion_rate_mb: 20
ingestion_burst_size_mb: 50
max_cache_freshness_per_query: 10m
max_streams_per_user: 0
query_scheduler:
max_outstanding_requests_per_tenant: 4096
frontend:
max_outstanding_per_tenant: 4096
compress_responses: true
memcached:
chunk_cache:
enabled: true
host: chunk-cache-memcached.loki.svc
service: memcached-client
batch_size: 256
parallelism: 10
results_cache:
enabled: true
host: results-cache-memcached.loki.svc
default_validity: 12h
serviceAccount:
create: false
backend:
replicas: 1
persistence:
storageClass: "managed-csi-premium"
storageClassName: managed-csi-premium
write:
replicas: 1
persistence:
read:
replicas: 1
memberlist:
service:
publishNotReadyAddresses: true
monitoring:
dashboards:
enabled: false
selfMonitoring:
enabled: false
lokiCanary:
enabled: false
test:
enabled: false
compactor:
replicas: 0
