Drop all logs except two name spaces in promtail
I am using the below promtail configuration
I need to drop all logs except 2 namespaces. But still full logs are coming ?
promtail:
config:
lokiAddress: loki-distributed-gateway
snippets:
common:
- action: replace
source_labels:
- __meta_kubernetes_pod_node_name
target_label: node_name
        - action: replace
          source_labels:
            - __meta_kubernetes_namespace
          target_label: namespace
        - action: replace
          replacement: $1
          separator: /
          source_labels:
            - namespace
            - app
          target_label: job
        - action: replace
          source_labels:
            - __meta_kubernetes_pod_name
          target_label: pod
        - action: replace
          regex: true/(.*)
          replacement: /var/log/pods/*$1/*.log
          separator: /
          source_labels:
            - __meta_kubernetes_pod_annotationpresent_kubernetes_io_config_hash
            - __meta_kubernetes_pod_annotation_kubernetes_io_config_hash
            - __meta_kubernetes_pod_container_name
          target_label: __path__
      pipelineStages:
        - docker: { }
        - multiline:
            firstline: '^[[:space:]]*\[java\] \d{4}-\d{1,}-\d{1,} \d{1,}:\d{1,}:\d{1,},\d{1,}
            [[:graph:]]* [A-Z]{4,}[[:space:]]*[[:graph:]]* - '
      scrapeConfigs: |-
        # Pods with a label 'app.kubernetes.io/name'
        - job_name: kubernetes-pods-app-kubernetes-io-name
          pipeline_stages:
            {{- toYaml .Values.config.snippets.pipelineStages | nindent 4 }}
          kubernetes_sd_configs:
            - role: pod
          relabel_configs:
            - action: replace
              source_labels:
                - __meta_kubernetes_pod_label_app_kubernetes_io_name
              target_label: app
            - action: drop
              regex: ''
              source_labels:
                - app
            - action: replace
              source_labels:
                - __meta_kubernetes_pod_label_app_kubernetes_io_component
              target_label: component
            {{- if .Values.config.snippets.addScrapeJobLabel }}
            - action: replace
              replacement: kubernetes-pods-app-kubernetes-io-name
              target_label: scrape_job
            {{- end }}
            {{- toYaml .Values.config.snippets.common | nindent 4 }}
what am I doing wrong here
also when we parse the logs, its not detecting new keyvalu pairs other than the labels we have specified in the config
Is that your entire promtail configuration? You seem to have two pipeline stages, and the only drop action I see is evaluated against app label.
This is how I usually drop logs:
scrape_configs:
- job_name: something
  static_configs:
  <CONFIG...>
  pipeline_stages:
  <OTHER_CONFIG...>
  - match: # Drop logs that don't match
      selector: '{label!="value"}'
      action: drop
      drop_counter_reason: non_essential_log
  - match:
      selector: '{label="value"}'
      stages:
      <OTHER_STAGES>
