Grafana 11.2.2 in windows 10
I want to create a text box in the draw.io diagram. The value in the textbox should vary with time linked to a data source. Like a stat panel in grafana dashboard, but inside the draw.io diagram.
I am not sure how to go about making it. I would like to know if it is possible. If possible, help would be appreciated.
check this out
