I recently read @marcusolsson’s wonderful post on How I use Docker for plugin development to give me a kick start with getting a development environment up and running. Something that became bothersome for me whilst working on a panel plugin was needing to (or forgetting to) refresh the browser every time I made a change. In this post, I’ll show you how to automatically refresh the browser while developing your plugin.
The live reload webpack plugin allows Webpack to spin up a server that can trigger a webpage to reload after a successful build.
To implement the webpack plugin in a Grafana plugin Docker environment:
Create a
Dockerfileto extend the Grafana image. This sets up some useful environment variables and usessedto inject thelivereload.jsinto theindex.htmlfile so the Webpack plugin can function.# Dockerfile FROM grafana/grafana:latest # Make it as simple as possible to access the grafana instance for development purposes # Do NOT enable these settings in a public facing / production grafana instance ENV GF_AUTH_ANONYMOUS_ORG_ROLE "Admin" ENV GF_AUTH_ANONYMOUS_ENABLED "true" ENV GF_AUTH_BASIC_ENABLED "false" # Set development mode so plugins can be loaded without need to sign ENV GF_DEFAULT_APP_MODE "development" # Load useful plugins to help with development ENV GF_INSTALL_PLUGINS "marcusolsson-static-datasource" # Inject livereload script into grafana index.html USER root RUN sed -i 's/<\/body><\/html>/<script src=\"http:\/\/localhost:35729\/livereload.js\"><\/script><\/body><\/html>/g' /usr/share/grafana/public/views/index.htmlI like
docker composeas it saves me having to remember the run commands for spinning up containers. -
Create a
docker-compose.ymlfile.# docker-compose.yml version: "3.0" services: grafana: container_name: grafana-basic-panel # build the Dockerfile so the container image has the livereload script embedded build: . ports: - 3000:3000 volumes: # mount the plugin "dist" directory inside the container - ./dist:/var/lib/grafana/plugins/basic-panel -
Run the following to build the Dockerfile image and start a Docker container running on http://grafana.staged-by-discourse.com:
docker-compose up -d -
Install the Webpack plugin.
yarn install --dev webpack-livereload-plugin -
Create a
webpack.config.jsto extend the@grafana/toolkitwebpack config with the following:const LiveReloadPlugin = require("webpack-livereload-plugin"); module.exports.getWebpackConfig = (config, options) => ({ ...config, plugins: [...config.plugins, new LiveReloadPlugin()], }); -
Run
yarn devto start developing a plugin.
When webpack rebuilds the plugin it triggers a browser refresh on http://grafana.staged-by-discourse.com.
