Do you know if Grafana has Cursor measurements functionality similar to osciloscopes?
Hi Everyone,
I set up my first Dashbord yesterday.
I am displaying time series data.
I am measuring soil humidity.
I am looking for similar " Cursor measurements" functionalities that you can find on Oscilloscopes.
There usually, you can do things like
Select an interval on the graph and get:
  • How long the time interval is
  • The min and max values in that interval
  • The rate of change of the value over the interval
  • The area under the graph
The most i was able to get was , on a Time Series Graph , under Legend, to add “Range” and so get the Min / Max of the displayed interval.
Do you know if this is covered by the default functionality or a plugin?
Thanks,
-Bogdan-
Hi @bogdanbelcea
What is your datasource? If you can use InfluxDB & Flux for queries, all of these things you want to know are fairly straightforward to calculate & display for a given time interval.
HI @grant2
Yes, I am using InfluxDB and Flux for the query.
I’ll will calculate the data via the query and figure out how to display it somewhere on the graph.
Thanks for the hint.
