I’m currently trying to deploy loki with a distributed configuration to my swarm cluster
For my setup, I’m only planning on splitting loki up with query-frontend, write and read components (since a lot of online references follow this logic)
I’m running into issues getting the cluster to work correctly. I’ve had success with a single node configuration but I wanted to have the option to scale up.
I’m using traefik as a reverse proxy for handling client requests
Errors I’m getting are:
"Remote state is encrypted and encryption is not configured\n\t* Failed to join VIRTUAL_IP:7946: Remote state is encrypted and encryption is not configured"
Where VIRTUAL_IP is the virtual ip configured for the swarm cluster which traefik handles. I’m not exactly sure what encryption means in this context, there’s not a lot of information found online aside from things related to consul.
msg="POST /loki/api/v1/push (500) 689.391µs Response: \"at least 2 live replicas required, could only find 1\\n\"
I imagine this has to do with the number of available ingesters not being available (since the ingesters can’t join the gossip ring). If I access ring or memberlist endpoints, I will only see one node.
I’d appreciate an extra pair of eyes that can see what exactly I’m missing or what I ‘oofed’ on.
Configuration:
Docker Stack File
loki:
command: -config.file=/etc/loki/local-config.yaml -target=query-frontend -frontend.downstream-url=http://loki-read.org.com
deploy:
mode: replicated
replicas: 3
labels:
- traefik.http.routers.loki.rule=Host(`loki-swarm.org.com`)
- traefik.http.routers.loki.entrypoints=http
- traefik.http.services.loki_svc.loadbalancer.server.port=3100
- traefik.http.routers.loki.service=loki_svc
# Memberlist
- traefik.http.routers.loki_ml.rule=Host(`loki-swarm.org.com`)
- traefik.http.routers.loki_ml.entrypoints=memberlist
- traefik.http.services.loki_ml_svc.loadbalancer.server.port=7946
- traefik.http.routers.loki_ml.service=loki_ml_svc
loki-write:
command: -config.file=/etc/loki/local-config.yaml -target=write
deploy:
mode: replicated
replicas: 3
labels:
- traefik.http.routers.loki_write.rule=Host(`loki-write.org.com`)
- traefik.http.routers.loki_write.entrypoints=http
- traefik.http.services.loki_write_svc.loadbalancer.server.port=3100
- traefik.http.routers.loki_write.service=loki_write_svc
# Memberlist
- traefik.http.routers.loki_write_ml.rule=Host(`loki-write.org.com`)
- traefik.http.routers.loki_write_ml.entrypoints=memberlist
- traefik.http.services.loki_write_ml_svc.loadbalancer.server.port=7946
- traefik.http.routers.loki_write_ml.service=loki_write_ml_svc
loki-read:
command: -config.file=/etc/loki/local-config.yaml -target=read
deploy:
mode: replicated
replicas: 3
labels:
- traefik.http.routers.loki_read.rule=Host(`loki-read.org.com`)
- traefik.http.routers.loki_read.entrypoints=http
- traefik.http.services.loki_read_svc.loadbalancer.server.port=3100
- traefik.http.routers.loki_read.service=loki_read_svc
# Memberlist
- traefik.http.routers.loki_read_ml.rule=Host(`loki-read.org.com`)
- traefik.http.routers.loki_read_ml.entrypoints=memberlist
- traefik.http.services.loki_read_ml_svc.loadbalancer.server.port=7946
- traefik.http.routers.loki_read_ml.service=loki_read_ml_svc
loki.yaml
auth_enabled: true
analytics:
reporting_enabled: false
server:
http_listen_port: 3100
log_level: debug
common:
compactor_address: http://loki-write.org.com
memberlist:
join_members:
- 'loki-write.org.com'
- 'loki-read.org.com'
dead_node_reclaim_time: 30s
gossip_to_dead_nodes_time: 15s
left_ingesters_timeout: 30s
gossip_interval: 2s
bind_addr: ['0.0.0.0']
bind_port: 7946
distributor:
ring:
kvstore:
store: memberlist
ingester:
wal:
enabled: true
dir: /loki/wal
lifecycler:
join_after: 10s
observe_period: 5s
ring:
kvstore:
store: memberlist
replication_factor: 3
final_sleep: 0s
chunk_idle_period: 5m
chunk_retain_period: 30s
flush_op_timeout: 10s
max_chunk_age: 1m
schema_config:
configs:
store: boltdb-shipper
object_store: s3
schema: v11
index:
prefix: index_
period: 24h
storage_config:
boltdb_shipper:
active_index_directory: /loki/index
cache_location: /loki/index_cache
resync_interval: 5s
shared_store: s3
aws:
s3forcepathstyle: true
bucketnames: loki
endpoint: dev-minio.org.com
region: us-east
access_key_id: user
secret_access_key: pass123
insecure: true
sse_encryption: false
limits_config:
enforce_metric_name: false
reject_old_samples: true
reject_old_samples_max_age: 30m
compactor:
working_directory: /loki/boltdb-shipper-compactor
shared_store: aws
compaction_interval: 5m
