how do i display only the value of instance:
Hello, have you checked this?
i’m not an expert in grafana but it seem that it will work only if i have a single data.
i get this error:
Organize fields only works with a single frame. Consider applying a join transformation or filtering the input first.
if i filter the data and get only the values from one of the 3 nodes it work
im also open to other visualization methods or queries, all i want is to understand how much nodes i have and if the container is running or not
Try to use Join by field transformation before Organize fields. Just as error message suggests.
I have found the an answer: join by label. It still in beta but it will work.
Thanks for pointing me in the right direction
