Display error logs in alert notification for Loki
    grafana/grafana:9.5.3
    grafana/loki:2.6.1
    Set up Slack alert notifications in Grafana that include the error logs in them.
Following this documentation: Alerting and Recording Rules | Grafana Loki documentation
I have an alert rule with the following query, using a Loki data source:
rate({app=“agones”} |= error [$__interval])
Then, I create a contact point with a webhook URL to a Slack channel:
Title:
{{ len .Alerts.Firing }} firing, {{ len .Alerts.Resolved }} resolved
In the text body, that is where I would like to display the error log.
  • What happened?
The alert notification displays in Slack, but I can’t figure out how to display the error message from the logs.
I would like to figure out a way to get the logs to display in the alert notification.
I have followed this similar topic: Including full log error message in alert notification using Loki
A work around has been suggested to generate a label based on a pattern query
pattern `<_> <_> <log_message>`
Even though I have tested several ways to get this query to work, like replacing the ` with ", but I am always getting an error message in Grafana:
Failed to evaluate queries and expressions: failed to execute query A: parse error at line 1, col 79: syntax error: unexpected STRING
I would appreciate any insight on this.
Thank you.
Show us the contents of the “A” query that is giving you the error.
sum by(log_message) (rate({app="agones"} |= `error` | pattern `<_> <_> <log_message>` [$__interval]))
Actually, I noticed that it work with Grafana 10+
Earlier versions of Grafana return the String error mentioned in my thread.
