I am trying to send a notification to Slack, when my alert triggers (alert query details at the end).
My alert triggers when it catches an error in the logs (from a loki data source).
In the contact points, I am trying to understand what I can collect and display from the alert itself, by putting this:
{{ range .Alerts.Firing }}
Here is everything: {{ . }}
{{ end }}
This displays the following output when I get 1 alert:
Here is everything: {firing alertname=Agones errors, grafana_folder=log-monitor description=Trying to display the log_message: {{ $log_message }}., summary=Here are the labels related to the alert: __alert_rule_namespace_uid__=DYYJLTgSk, __alert_rule_uid__=E2vxYTRSz, alertname=Agones errors, grafana_folder=log-monitor. 2023-08-22 21:51:30 +0000 UTC 0001-01-01 00:00:00 +0000 UTC http://localhost:3000/alerting/grafana/E2vxYTRSz/view?orgId=1 1661f2d935f5cc1b http://localhost:3000/alerting/silence/new?alertmanager=grafana&matcher=alertname%3DAgones+errors&matcher=grafana_folder%3Dlog-monitor&orgId=1 map[B0:1] [ var='B0' metric='Value' labels={log_message=http: TLS handshake error from 172.29.0.0:4307: EOF} value=1 ] }
I would like to understand how to navigate through this output and display something that may be a little easier to read, like:
At 2023-08-22 21:51:30 +0000 UTC 0001-01-01 00:00:00 +0000 UTC
error log: http: TLS handshake error from 172.29.0.0:4307: EOF
View it in Grafana: http://localhost:3000/alerting/grafana/E2vxYTRSz/view?orgId=1 1661f2d935f5cc1b http://localhost:3000/alerting/silence/new?alertmanager=grafana&matcher=alertname%3DAgones+errors&matcher=grafana_folder%3Dlog-monitor&orgId=1
The query to generate the alert is as follow:
sum by(log_message) (rate({app="agones"} |= `err` | pattern `<_> <_> <log_message>` [$__interval]))
Then, I generate an alert whenever this sum is > 0:
That is how I am generating a label: log_message, so that I am hopeful to use that label in the alert notification.
Thanks for helping me out with this.
