In a dashboard I’m using both template variables (ie variable which are defined in Dashboard / Settings / Variables) and a variable which is set by an Interactive Tree Panel.
Both kind of variables are displayed in dashboard url like so
var-campaign=TestCampaign0&var-campaign=TestCampaignScope0&var-timeseries=HUM0&var-ts_data_state=Raw&var-timeseries2=RW0&var-location=space-6&editPanel=4
campaign, campaign, timeseries, ts_data_state, timeseries2 are template variables but location is set when clicking on a node of Interactive Tree Panel.
Unfortunately theses variables seems to behave differently when trying in a table row to display then.
For example this query
WITH t AS (
SELECT 1 AS level, 'site' AS type
UNION ALL
SELECT 2, '${timeseries}'
UNION ALL
SELECT 3, '${location}'
SELECT *
FROM t;
displays this
ie ${location} is displayed… instead of its value which is in url (space-6 here)
I don’t know why these variables behave differently and how location can be rendered
Some help will be very kind
