I have several alerts setup on multiple grafana dashboards and panels. I have alerts setup and they are working pretty well but I want to cut down on email noise. Is there a way to disable the [OK] alert that gets emailed out if the alert goes away? If I get an alert I go check on it no matter what and need to verify that it is ok so that email serves no purpose for me.
Hi! You can click Disable resolved message in the configuration of your contact point.
