I would like to know if it is possible to disable multi dimensional alerts without using classic condition. I use a Math expression to check for my alert condition which is very handy. I have multiple instances of the alert (and therefore multiple alert notifications) when I really need to be notified once when one of the instance is firing.
Hi @rorfis
Couldn’t you just adjust your alert query to include ONLY the instance that you want to alert on?
No I actually want one alert if one or multiple instance are firing, no matter the instance.
