I have a problem with the display of different values on a graph with bar.
The request are in timescale DB, I’m making the sum each day of the data but the problem is that on the same bar you have 2 values (on the first half of the bar you have the value of the precent bar and on the second half of the bar you have the right value). See on the following picture:
The version of Grafana is 6.7.5. Any solution to workaround this problem?
