Hi My applications are heavily using oracle db, completely dependent on the enterprises level features offered by the oracle db
I want to use alloy to capture the metrics of the oracle db, standard metrics, tables data,
- Alert log,
- Listener Log,
- Blocker queries/Waiter queries,
- Top 10 sessions with their OS PIDs
- CPU Consumption
- Disk space usage (mount points)
And the idea is to not have the agent directly installed on the same server as db.
I also want to understand the difference between the 2 options to scrape the metrics from the oracle db
Grafana Integration oracle DB
Grafana alloy exporter config
