I have had a grafana server (10.1.2) running on a RPi4-4GB running Bullseye for many months on my local network (no outside access available, as far as I know.) It plots temperature data collected from ESP8266’s using MQTT through a custom python program to an influx data base. For convenience, I have set the logon to anonymous so all my devices from Ubuntu PC’s to Android tablets can view Grafana.
First indication of trouble was (I think) last week. Out of the blue, I was presented with a logon demand instead of my usual dashboard plots. WTF!!! Am I hacked? So I edit the /usr/share/Grafana/conf/defaults.ini to set enabled = true in the [auth.anonymous] config section. (It was mysteriously set to false.) My dashboards were then loaded as usual.
As of Saturday, Grafana server no longer responds.
One thing I know to do is check systemctl status:
sudo systemctl status grafana-server
- grafana-server.service - Grafana instance
Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
Active: inactive (dead) (Result: exit-code) since Mon 2024-01-29 16:06:20 PST; 30s ago
Docs: http://docs.grafana.org
Process: 28970 ExecStart=/usr/share/grafana/bin/grafana server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid --packaging=deb cfg:default.paths.logs>
Main PID: 28970 (code=exited, status=2)
CPU: 95ms
Jan 29 16:06:20 rpi4lib systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 1953.
Jan 29 16:06:20 rpi4lib systemd[1]: Stopped Grafana instance.
lines 1-10/10 (END)
So it appears to be restarting and failing, but I have no way to debug this further.
My only idea at this point is to uninstall and reinstall grafana. Luckily, I stored an export json of my latest dashboard, since I can’t do that now.
I found this
Should I:
- partial
sudo apt-get remove grafana
OR 2. Uninstall grafana and its dependencies:
sudo apt-get remove --auto-remove grafana
Any help appreciated!
