Hi, I would like to compare histogram, so I need a density/normalized plot. I found this issue but still strugling. I’m using grafana version v8.2.3, qurying data from InfluxDB 2.0 with the following Flux query:
from(bucket: “GPS”)
|> range(start: v.timeRangeStart, stop:v.timeRangeStop)
|> filter(fn: (r) =>r._field == “speed” and r._value > 0.0)
I can get histograms with the graph panel or histogram panel but no way to get a relative Y-axis from 0-1, even with setting the Y-units.
Any help would be appreciated, in advance thank you.
