Delay in Grafana dashboard with Zabbix data
I have Zabbix installed and working with postgras sql.
I have the grafana working with the Zabbix API server queries and its working fine.
My problem there is a 5 minutes delay between what Zabbix poll to what grafana query present.
I.e. i see everything 5 minutes after it happen.
Any idea how to solve it?
Thank you in advance.
Best,
Eyal.
Check that the system time is synced between both your source and grafana.
Hope it helps.
Good Luck
Hey,
Thank you for your response and taking time to respond.
The Zabbix, dB and Grafana server/GUI are on the same VM with the same time. This is why im frustrated.
Any additonal ideas?
Best,
Eyal Cohen.
Mobile:+972542224114
I have the same problem. Do you solve? Any idea?
For example, in Zabbix, the last item collected at 11:15 am, but in grafana only appears until 11:09 am.
I have the same issue, also seems that querying is slow. Anyone ever found a fix?
Could anyone solve this issue ? I have a query that is running every second on zabbix so I need to show output on the grafana but it is showing with delay . How can solve it ?
