Grafana 8.5.3 deployed pm k8s with Promtheus-stack helm chart. -
Increase the timeout of promtheus quries -
we increased the timeout in prometheus datasource configuration and in addition in grafana.ini we increased the dataproxy timeout ,
but the timeout still 30s -
What happened?
still getting time out after 30s -
timeout to be changed according to when we defined (bigger than 30s) -
grafana.ini:
dataproxy:
logging: true
timeout: 900
keep_alive_seconds: 900
dialTimeout: 900
tls_handshake_timeout_seconds: 900
additionalDataSources:
- name: Prometheus
type: prometheus
url: http://prometheus-stack-kube-prom-prometheus.monitoring:9090/
access: proxy
isDefault: true
jsonData:
timeInterval: 30s
queryTimeout: 900s
manageAlerts: false
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
Grafana UI error:
