Hi there,
I noticed that Grafana already allows you to define an admin user in the .ini configuration files. Is it possible to also define a viewer user in the .ini configuration files?
I don’t mind if the password for that user has to be stored in the file as plain text, that user will be mainly used to prevent less technical people from accidentally messing with or deleting any dashboards.
I know I could create a viewer user by hitting the HTTP endpoint, but I would like to do it this way only as a last resort, defining the viewer user in the .ini file would be better for my case…
