Hi there!
I have a noob question, which is likely more connected to typescript than to Grafana plugin development, but someone here might be able to help.
I am developing a simple datasource plugin, it does not matter what is the backend. The hard part for me is the query editor. What I can do now is using simple Select field like this:
<div className="gf-form">
<Select
prefix="Metric: "
options={myoption}
This gives me a rolldown menu of options. The question is how to
a) format it as options in eg. Graphite datasource (Series in picture)
b) add ‘+’ sign to add as many options as desired (Functions in picture)
Options will be given in a simple Array variable, but I cannot make it work. I tried to use code from Graphite datasource plugin, but there are too many dependencies to make it work. There must be some simple solution I don’t see. Also, I am using a tsx QueryEditor as in the plugin devel tutorial, not the class version with html template, as in Graphite plugin.
Picture of desired state:
