Datasource does not load, after manual reload (service grafana-server restart)
    7.5.7 grafana
    Ubuntu (AWS-provided EC2 image with apt install)
    I am trying to edit or add a datasource.
    Previously, this worked. (Until I restart the server, via Ubuntu ‘grafana-server’ service.)
    after using the cli,
    through the ui. Example:
$ grafana-cli plugins install grafana-worldmap-panel
installing grafana-worldmap-panel @ 0.3.2
from: grafana.com/api/plugins/grafana-worldmap-panel/versions/0.3.2/download
into: /var/lib/grafana/plugins
:heavy_check_mark: Installed grafana-worldmap-panel successfully
Restart grafana after installing plugins .
ubuntu@ip-xx-xx-xx-xx:~$ sudo service grafana-server restart
… when that didn’t work (see below) I attempted to edit files:
sudo vi /usr/share/grafana/conf/defaults.ini
with:
allow_loading_unsigned_plugins = fetzerch-sunandmoon-datasource,grafana-timestream-datasource,grafana-worldmap-panel
  • What happened?
    when attempting to add any of the unsigned plugins, it is not available (does not show up in search box)
    Plugins would show up, when matching terms typed into filter.
    OR
    When clicking on an existing plugin, some settings page should occur.
    when attempting to edit existing datastore: "Plugin not found, no installed plugin with that id
Oh, and after a soft reboot, I had to start the grafana-server, using cli
logs:
t=2021-05-28T07:44:53+0000 lvl=eror msg=“Could not find plugin definition for data source: grafana-timestream-datasource”
t=2021-05-28T07:44:53+0000 lvl=eror msg=“Could not find plugin definition for data source: fetzerch-sunandmoon-datasource”
    No
just to clarify: what previously “worked”? Are you saying that you could, at one point, install these plugins using that grafana-cli command?
You can close this. I found a ‘workaround’ which is to say, I stopped doing dumb things.
The ‘problem’ is that all grafana panels in my dashboard are suddenly using a random walk datasource, instead of the configured AWS Timestream datasource (‘grafana-timestream-datastore’)
The additional information that I now have is: After additionial experimentation, it appears the datasources stop being available to grafana at some point during the install of some unrelated system-level libraries. I think something to do with React. (Obviously not as unrelated as I thought!)
This is obviously a problem with my practice of co-locating some development resources on the same machine. You can close this issue – I will just stop doing that.
