Hello all,
I have the following problem in Grafana v9.0.3
I aggregate data in a widget with a different time frame (24hr) than the dashboard (30m).
When I close my table or stat widget, the dashboard refreshes and I lose some data.
For instance the sum of scrap_qty goes from 15 to 13.
When I reopen the widget and click in and out the query, the correct values appear again.
Do you know what might cause this?
