Data links result in empty values for certain URL variables
I am baffled by this behavior. I have a data link A in dashboard A where there are some template variables X, X, Y. When I hover over the data link url, is see it looks perfect. For example:
https://myaccount.grafana.net/d/aebiq07x48tmoa/dashboard-b?from=now-1h&to=now&timezone=utc&var-A=33&var-B=1&var-C=9)
But, when I click the link and dashboard-b opens, the url bar in the browser randomly presents some of the url variables with empty values. Like this:
https://myaccount.grafana.net/d/aebiq07x48tmoa/dashboard-b?from=now-1h&to=now&timezone=utc&var-A=&var-B&var-C=9)
Here, the values for A and B are now empty but C and the timestuff is ok.
Any ideas on why this happens? It is not always the same A, B, or C values that show up empty. Sometimes they are all ok and dashboard-b works.
Thanks!
What version of grafana
Sorry, rushed that post and failed to provide that.
11.5.0-81732
the latest is
where did you find this version of yours :slight_smile:
We are using Grafana cloud. It does not present any “About…” options that I can find like the local hosted server version does.
curl -s “$GRAFANA_URL/api/health” | jq -r ‘.version’
just tested this in play.grafana.com and I am not seeing this issue?
on hover notice link with template variable
on click it takes me to
I’m having this issue as well. Grafana version: grafana/grafana-enterprise:latest, which Docker resolves to Grafana v11.5.1 (c6c701cf5b).
The issue is not intermittent, but persistent for some data links. Other links, from the same dashboard, work well.
