Data links dont work in extended graph panel
Im using version 6.4.3
When I try to add a data link to an extended graph panel, clicking on a line does not yield any result. It doesn’t even give the “Annotate” option anymore.
If I then convert that same panel to a graph panel instead of extended graph panel then everything works fine. Any solution?
