Data disappears when grouping a count by a term
I have an existing query that shows plenty of data:
Looking in elasticsearch, we can see that each result has a value in the proxy_upstream_name term.
But when I try to group my Grafana query by proxy_upstream_name, all the data in my chart disappears.
I expected it to appear similar to the “Expected” image above, but with a line and legend entry for “mad-pig-apicontent-80” and all other proxy_upstream_name values .
What am I doing wrong here?
Can you investigate the query sent to Elasticsearch and elasticsearch response? Chrome dev tools network tab. Maybe there is something wrong with the query or the ES response
How to troubleshoot metric queries:
Thanks for the pointers! Elasticsearch response showed the following error message:
Fielddata is disabled on text fields by default. Set fielddata=true on [proxy_upstream_name] in order to load fielddata in memory by uninverting the inverted index. Note that this can however use significant memory.
Which lead me to this Elasticsearch page and then I queried my logstash-* mappings in elasticsearch like so:
curl https://my-elasticsearch.us-east-1.es.amazonaws.com:443/logstash-*
Looked at the mapping for proxy_upstream_name:
"proxy_upstream_name": {
    "fields": {
        "keyword": {
            "ignore_above": 256,
            "type": "keyword"
    "type": "text"
Saw that it already had a keyword, so I merely had to change my group by term name to proxy_upstream_name.keyword and groupings worked! Hooray.
