Grafana v11.4.0 (b58701869e) on Raspi Debian Bookworm
did do update - upgrade sequence von my raspi.
After that the dashboard view had changed, there is another line on the top, which wastes place…
I cannot see and hint in the release notes… so
- what did happen ?
- is there a way to configure back to old status?
2 screenshot attached, before and after upgrade.
Hi
I think the line came with scenes powered dashboards. I’m not sure you can disable this rn but you can try to look into scenes (with this the bar is also sticky, so you don’t have to move up to the top of the dashboard to change time or variables).
Yes… that’s it.
Obviously came with v11.3.
And it seems as if you cannot move the new position of the timepicker back to where it was before because that is a new introduced feature that it became sticky and visible on the top, regardless where you scroll in the dashboard.
Thanks for that information !
