Screenshot: I want to configure the filter to have “All” and each domains data selector, But I click “All” it only shows the first domain’s data, and also I select another domain it still showed the first domain’s data.
My filter source is come from SQL, and I have tested without the “Multi-value” and “Include All option” in variables it works just fine in each domain. But, I enabled them it doesn’t worked. How can I fixed them?
Variables Screenshots:
