I am trying to import the dashboards and have the datasource set to prometheus. Following is my configmap. The dashboard id is 405. I am able to manually import it but its not working with helm
apiVersion: v1
kind: ConfigMap
metadata:
labels:
app: {{ template “grafana.name” . }}
chart: {{ template “grafana.chart” . }}
release: {{ .Release.Name }}
heritage: {{ .Release.Service }}
data:
{{ (.Files.Glob “custom-dashboards/node.json”).AsConfig | indent 4}}
in values.yaml i have it set as
dashboardProviders:
dashboardproviders.yaml:
apiVersion: 1
providers:
- name: ‘default’
orgId: 1
folder: ‘’
type: file
disableDeletion: false
editable: true
options:
path: /var/lib/grafana/dashboards/default
- name: ‘ds2’
orgId: 2
folder: ‘’
type: file
editable: true
options:
path: /var/lib/grafana/dashboards/ds2
dashboardsConfigMaps:
default: “istio-grafana-configuration-dashboards”
ds2: “custom-dashboards”
The dashboard related to istio are all visible when Grafana gets deployed. but the custom-dashboard is not visible in GUI. in the logs i see no errors .
configmaps appears to be correct
kubectl get cm/custom-dashboards -n monitoring -o yaml
apiVersion: v1
data:
node.json: |
“__inputs”: [
“name”: “DS_PROMETHEUS”,
“label”: “Prometheus”,
“description”: “”,
“type”: “datasource”,
“pluginId”: “prometheus”,
“pluginName”: “Prometheus”
“__requires”: [
“type”: “panel”,
“id”: “graph”,
“name”: “Graph”,
“version”: “”
“type”: “grafana”,
“id”: “grafana”,
“name”: “Grafana”,
“version”: “3.1.0”
“id”: “prometheus”,
“name”: “Prometheus”,
“version”: “1.0.0”
“id”: null,
“title”: “Node Exporter Server Metrics”,
“description”: “Dashboard to view multiple servers”,
“tags”: [
“prometheus”
“style”: “dark”,
“timezone”: “browser”,
“editable”: true,
“hideControls”: false,
“sharedCrosshair”: false,
“rows”: [
“collapse”: false,
“editable”: true,
“height”: “25px”,
“panels”: [
“content”: “”,
“editable”: true,
“error”: false,
“id”: 11,
“minSpan”: 2,
“mode”: “html”,
“repeat”: “node”,
“span”: 12,
“style”: {},
“title”: “$node”,
“type”: “text”
“title”: “Title”
“collapse”: false,
“editable”: true,
“height”: “25px”,
“panels”: [
“cacheTimeout”: null,
“colorBackground”: false,
“colorValue”: false,
“colors”: [
“rgba(245, 54, 54, 0.9)”,
“rgba(237, 129, 40, 0.89)”,
“rgba(50, 172, 45, 0.97)”
“datasource”: “Prometheus”,
“editable”: true,
“error”: false,
“format”: “none”,
“gauge”: {
“maxValue”: 100,
“minValue”: 0,
“show”: false,
“thresholdLabels”: false,
“thresholdMarkers”: true
Suggestions ?
