Dashboard combine 2 tables
i have 2 panels, each panel is a table with several queries. the tables are the same and i want to connect them together, however i cant just copy the queries because in each panel the transformation is different
I would first try to implement all transformations directly in the queries.
Do you have a specific example?
i have done it,
used all the transformation as parsing in each queries
works great
thanks :smile:
