I just wanted to know if there is a way to hide the “Thresholds mode: absolute/percent” in the config for my custom panel.
resp. we don’t want to be able to have the thresholds in percent
You should be able to remove the threshold editor all together, but I don’t believe you can disable absolute or percent separately.
