9.1.3 -
Each Site in in my environment has 30 servers but few sites has only 27 servers. Each site has a unique number and the relevant servers are grouped accordingly. On grafana dashboard, I have created the below query to count the total servers which are up and then color code based on their values. On the value mappings for the value 30 it will display in Green color and rest others in Red color. Since our environment few sites has only 27 servers it is showing in Red for those even though all servers are up at that site. Since I know which site has only 27 servers I want to use some kind of expression and when processing it, anything matches the hardcodes site number in a variable and if all the 27 servers are up mark it Green. Some kind of override i need for this special case.
Query:
sort (count by(Site) (probe_success{Site=~"$Site"} == 1))
Value Mappings
30 → Green
27 to 29 → Yellow
1 to 26 → Red
Using the below query it works only for the site which has 30 servers but for the sites which only 27 servers.
Query:
What happened?
For the sites which has 27 servers it is showing Red color but the whole site is up & running. -
I want to create expression in such a way that it works for both 27 servers site and also 30 servers site. Since I know which site has 27 servers I want to hardcode it but not sure how to do it. -
Query:
No errors. -
No, I did not follow any.
