Custom DataSource
How to enable customer datasource, like querying from KSQL DB tables/sttreams.
Thanks
Venkata Madhu
Can share some more details on what you’d like to do? It sounds like you want to add support for a custom data source. If you want to get started developing data source plugins, check out this tutorial: Build a data source plugin.
Hi Marcusolsson, We have changed our plan to use simpod-json-datasource to call the REST API to generate the dashboard.
Thanks
Venkata
Hello friend, which version are you using? I’m trying to use simpod-json-datasource too, but it can not show in the grafana plugin list. I’m, using grafana 6.7.3 with simpod-json-datasource 0.2.0
Initially i was using grafana 6.7.1. It wasn’t showing the simpod-json-datasource plugin after it added. This behaviour was in Linux environment (it was working in windows).
Then i moved to Grafana 6.4.3, i can see the plugin in the list after it added using the plugin command
grafana-cli plugins install grafana-simple-json-datasource
I need to use the newest version… And I can just install the plugin offline.Anyway, thanks a lot.
I try to install Grafana 7.0.1. Found that when I unpack the simPod-grafana-json-datasource-v0.1.4-58-g3413784.zip in /var/lib/grafana/plugins, and rename the directory to simPod-json-datasource, it works.
For Grafana 6.7.3, the directory need to be renamed to SimpleJson to make it appear in the Granfa plugins page.
