Hello Community,
im completely new in this thing called “Grafana”
So i have a few questions.
I need to Create a Dashboard with Grafana , i get all the KPI from MSSQL-Server
Would you recommend using/creating it on Windows?
Which Plugins should i use?
Do you recommend a good tutorial for beginners?
Are there any good tips for beginners?
Hope you guys can help me.
Thanks
