10.2.2 (docker image in Docker Desktop)
Host OS Windows 10 -
I want to display csv data as multi time series. -
I use the CSV data source to retrieve my data from Victoria Metrics using the export api endpoint
https://docs.victoriametrics.com/#how-to-export-csv-data. The returned csv data does not have a header, hence the columns are called Field 1, Field 2,… To rename the columns I use the organize fields transformation and then apply the Prepare time series (Multi-frame time series) transformation.
- What happened?
The data is displayed as expected but the naming of the series still uses the initial column names e.g. Field 6 {Field 1=“59”, Field 2=“2”, Field 3=“1”, Field 4=“105”, Field 5=“{\r\n "input1": 1\r\n}”}
The naming of the series uses the correct field names e.g.
Execution Time {Deployment=“59”, Function=“2”, Resource=“1”, Resource Deployment=“105”, Request Body=“{\r\n "input1": 1\r\n}”} -
Example Data:
Example Data
59,2,1,105,"{\r\n \"input1\": 4\r\n}",4.0045208931,2024-01-12T07:42:55Z
59,2,1,105,"{\r\n \"input1\": 4\r\n}",4.004529476165,2024-01-12T07:43:22Z
59,2,1,105,"{\r\n \"input1\": 3\r\n}",3.003444910049,2024-01-12T07:35:10Z
59,2,1,105,"{\r\n \"input1\": 3\r\n}",3.003635406494,2024-01-12T07:43:16Z
59,2,1,105,"{\r\n \"input1\": 3\r\n}",3.003527879714,2024-01-12T08:17:00Z
59,2,1,105,"{\r\n \"input1\": 1\r\n}",1.0014128685,2024-01-12T07:35:23Z
59,2,1,105,"{\r\n \"input1\": 1\r\n}",1.001668453216,2024-01-12T07:45:21Z
59,2,1,105,"{\r\n \"input1\": 1\r\n}",1.001548767089,2024-01-12T08:16:55Z
59,2,1,105,"{\r\n \"input1\": 7\r\n}",7.00076007843,2024-01-12T07:35:20Z
59,2,1,105,"{\r\n \"input1\": 10\r\n}",10.006876230239,2024-01-12T07:36:13Z
59,2,1,105,"{\r\n \"input1\": 15\r\n}",15.0089175701,2024-01-12T08:17:16Z
59,2,1,105,"{\r\n \"input1\": 15\r\n}",15.015579462051,2024-01-12T08:26:11Z
This is the panel json:
Panel JSON
"datasource": {
"uid": "fbce2b04-0de4-4979-98d5-af04b2b6c66a",
"type": "marcusolsson-csv-datasource"
"fieldConfig": {
"defaults": {
"custom": {
"drawStyle": "points",
"lineInterpolation": "linear",
"barAlignment": 0,
"lineWidth": 1,
"fillOpacity": 100,
"gradientMode": "none",
"spanNulls": true,
"insertNulls": false,
"showPoints": "always",
"pointSize": 7,
"stacking": {
"mode": "none",
"group": "A"
"axisPlacement": "auto",
"axisLabel": "",
"axisColorMode": "text",
"axisBorderShow": true,
"scaleDistribution": {
"type": "linear"
"axisCenteredZero": false,
"hideFrom": {
"tooltip": false,
"viz": false,
"legend": false
"thresholdsStyle": {
"mode": "off"
"axisSoftMin": 0
"color": {
"mode": "palette-classic"
"mappings": [
"options": {
"Null": {
"index": 0
"type": "value"
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"decimals": 3,
"unit": "s"
"overrides": []
"gridPos": {
"h": 9,
"w": 24,
"x": 0,
"y": 18
"id": 6,
"options": {
"tooltip": {
"mode": "single",
"sort": "none"
"legend": {
"showLegend": true,
"displayMode": "list",
"placement": "bottom",
"calcs": []
"pluginVersion": "10.2.2",
"targets": [
"datasource": {
"type": "marcusolsson-csv-datasource",
"decimalSeparator": ".",
"delimiter": ",",
"header": false,
"ignoreUnknown": false,
"params": [
"format",
"deployment,function,resource,resource_deployment,requestBody,__value__,__timestamp__:rfc3339"
"match",
"function_execution_duration_seconds"
"start",
"$__from"
"end",
"$__to"
"path": "/api/v1/export/csv",
"refId": "A",
"schema": [
"name": "Field 1",
"type": "string"
"name": "Field 2",
"type": "string"
"name": "Field 3",
"type": "string"
"name": "Field 4",
"type": "string"
"name": "Field 5",
"type": "string"
"name": "Field 6",
"type": "number"
"name": "Field 7",
"type": "time"
"skipRows": 0,
"timezone": "UTC"
"title": "Previous Execution Times (last 30 min)",
"transformations": [
"id": "organize",
"options": {
"excludeByName": {
"Field 1": false
"indexByName": {},
"renameByName": {
"Field 1": "Deployment",
"Field 2": "Function",
"Field 3": "Resource",
"Field 4": "Resource Deployment",
"Field 5": "Request Body",
"Field 6": "Execution Time",
"Field 7": "Timestamp"
"id": "prepareTimeSeries",
"options": {
"format": "multi"
"type": "timeseries",
"interval": "1s",
"timeFrom": null
No -
CSV Datasource Documentation
