I would like a dashboard to monitor multiple servers. I’m running 7.1.1.
No problem. Each panel on the dashboard has its own data source.You just can’t mix queries from different data sources in a single panel.
Thanks. I should have been a little more specific. I’ve actually did that. Despite saving everything, when I return all the ones I copied changed back to the same data source of the original.
What I did was import a dashboard. It worked fine for the data source I used when creating it. I then copied a Panel and changed it to a different data source. Saved that panel, saved the dashboard. Returning the new panel showed the original one.
