Hi All,
I’ve a table panel on Grafana where I have a Duration column as below. I need to create an alert if the Duration is for example exceeds 10. Is there any way to achieve this?
Hi All,
Hi, I see you’re using multiple transformations. Are you able to achieve the duration field without the transformations (those won’t work in alerts).
You can create an alert by going to Alerts page and clicking Create new alert button. You can also manually connect that alert to the panel, even though there’s no Alert tab in visualizations other than Time Series.
