What Grafana version and what operating system are you using? Grafana V11.4 on Ubuntu
I am trying to build a dashboard that monitors Crowdsec kernel log. Idea is to make a table that
lists top 3 IP’s (by aggregation) that tried to access any port on my server.
The log format is :
2025-01-04T00:42:38.638415-05:00 peronalserver kernel: crowdsec drop: IN=dni6p3 OUT=docker0 MAC=<mac id> SRC=127.0.0.1 DST=127.0.0.2 LEN=44 TOS=0x00 PREC=0x00 TTL=238 ID=00000 PROTO=TCP SPT=00000 DPT=80 WINDOW=00000 RES=0x00 SYN URGP=0
Example:
IP = Count
1.1.1.1 = 32
2.2.2.2 = 12
3.3.3.3 = 5
Using Promtail to read Kern.log and running this query in Panel Addsum by (ip) (
count_over_time({service_name="system_logs"} |= "crowdsec drop" | pattern `<_>SRC=<ip> <_>` | __error__="" [$__range]) )
- What happened?
Its creating a table thats is displaying data with timestamps for each count of the selected IP, but it’s not aggregating all IPs or limiting the display to the top 3…
Output Table:
Time = 127.0.0.1 (column header)
2025-01-04 01:20:00 = 1
2025-01-04 02:40:00 = 1
2025-01-04 03:20:00 = 1
2025-01-04 04:00:00 = 1
<Drop down list to select other IP’s>
a table that
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
None
Can someone please help me figure this out? Many thanks!
