Create a graph, which tells the average response time for each request
I already get a filtered log in Loki like this (0.1043 ms):
0.1043
0.0568
0.4888
0.1777
0.4656
0.4301
0.4581
So what I need visualization it.
I would like to visualization in Time series
{filename=“/var/log/test/benchmarking.monitoring.log”} | json | line_format “{{.response_time}}”
I would like to visualization like this :
but I’m doing something wrong, I’m writing the Logql command incorrectly
You’ll need to use unwrap to set a metric query’s value to a label. See example here: Query examples | Grafana Loki documentation
I try this request :
quantile_over_time(0.95, ({job="test"} | json | unwrap response_time)[1m])
it works, but it’s not one line, it’s multiple lines.
It’s not quite the same …
I want one single line, not a lot of line for every response time
If you want to aggregate by a label, add sum by (LABEL) around your quantile_over_time query. See How to use LogQL range aggregations in Loki | Grafana Labs.
