Grafana v7.5.7 -
I am trying to make a regular interval (For example 10min 20min 30min 40min …) on the left axis rather than an irregular interval as shown below.
What happened?
The left axis shows an irregular interval like 16.7min, 33.3min, 50min, 1.11 hour, 1.39 hour -
I am trying to make a regular interval (For example 10min 20min 30min 40min …) on the left axis -
"aliasColors": {},
"bars": true,
"dashLength": 10,
"fieldConfig": {
"defaults": {
"unit": "s"
"overrides": []
"fill": 1,
"gridPos": {
"h": 8,
"w": 12,
"x": 12,
"y": 1
"id": 23763571993,
"legend": {
"alignAsTable": false,
"avg": false,
"current": false,
"hideEmpty": false,
"hideZero": false,
"max": false,
"min": false,
"rightSide": false,
"show": true,
"total": false,
"values": false
"linewidth": 1,
"nullPointMode": "null",
"options": {
"alertThreshold": true
"pluginVersion": "7.5.7",
"pointradius": 5,
"renderer": "flot",
"seriesOverrides": [],
"spaceLength": 10,
"stack": true,
"targets": [
"format": "time_series",
"group": [],
"hide": false,
"metricColumn": "none",
"rawQuery": false,
"rawSql": "SELECT\n datetime AS \"time\",\n backup_duration AS \"Backup\"\nFROM storage_cohesity_backups\nWHERE\n datacenter = 'dc12' AND\n protection_group_name = 'DC12-FlashBlade-prodstore-Replication-AWS'\nORDER BY datetime",
"refId": "A",
"select": [
"params": [
"backup_duration"
"type": "column"
"params": [
"Backup"
"type": "alias"
"table": "storage_cohesity_backups",
"timeColumn": "datetime",
"timeColumnType": "datetime",
"where": [
"datatype": "varchar",
"name": "",
"params": [
"datacenter",
"'dc12'"
"type": "expression"
"name": "",
"params": [
"protection_group_name",
"'DC12-FlashBlade-prodstore-Replication-AWS'"
"group": [],
"hide": false,
"rawQuery": false,
"rawSql": "SELECT\n datetime AS \"time\",\n copy_duration AS \"Replication\"\nFROM storage_cohesity_backups\nWHERE\n datacenter = 'dc12' AND\n protection_group_name = 'DC12-FlashBlade-prodstore-Replication-AWS'\nORDER BY datetime",
"refId": "B",
"select": [
"params": [
"copy_duration"
"type": "column"
"params": [
"Replication"
"type": "alias"
"where": [
"name": "",
"params": [
"datacenter",
"'dc12'"
"name": "",
"params": [
"thresholds": [],
"timeRegions": [],
"title": "DC12-FlashBlade-prodstore-Replication-AWS",
"tooltip": {
"shared": true,
"sort": 0,
"value_type": "individual"
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"$$hashKey": "object:76",
"decimals": null,
"format": "s",
"label": "",
"logBase": 1,
"max": null,
"min": null,
"show": true
"$$hashKey": "object:77",
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"yaxis": {
"align": false,
"alignLevel": null
"dashes": false,
"fillGradient": 0,
"hiddenSeries": false,
"lines": false,
"percentage": false,
"points": false,
"steppedLine": false,
"timeFrom": null,
"timeShift": null,
"datasource": null
