Setting up a new Grafana server version v6.4.1 Centos 7, with multiple Organizations
Already had 2 Orgs Created
Using LDAPS
(no definitions for org 3 were in the LDAP toml yet but my user was part of a group definition that does not have an org ID so should not apply)
Created Org ID 3, and saved it. My current org changed to id 3 but noticed when I went to switch I only had the option of Org 1 or 3, not all 3 were listed.
Logged out. Was unable to log back in with my LDAP account (Error while trying to authenticate user), had to use the local admin.
Logged out. Updated the toml file to include org 3 but this should not have affected my account since my group is not org specific.
restarted Grafana, still was unable to log in with my user. Found in the log each time I try to log in with failed user:
t=2019-10-18T17:36:41+0000 lvl=eror msg=“Error while trying to authenticate user” logger=context userId=0 orgId=0 uname= error=“Cannot remove last organization admin”
t=2019-10-18T17:36:41+0000 lvl=eror msg=“Request Completed” logger=context userId=0 orgId=0 uname= method=POST path=/login status=500 remote_addr=<> time_ms=97 size=81 referer=https://myserver/login -
Failed user no long appears in the User interface and if I try to manually add that user it fails.
