Container logs are not showing in Grafana Loki
Currently I was configured container logs path in promtail config file.
Below is the config file:
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: /tmp/positions.yaml
clients:
  • url: http://:3100/loki/api/v1/push
scrape_configs:
  • job_name: system
    static_configs:
    • targets:
      • ip
        labels:
        job: varlogs
        path: /var/log/log
        path: /var/lib/docker/containers/1d1acb2468f1
        /1d1acb2468f1*log
