grafana the latest not sure where to find the verion number - What are you trying to achieve?
Make it work between the 4 - How are you trying to achieve it?
Follwing documentaion the proper config and yml files - What happened?
Can’t get it to work is get parsing errors, then bad request s - What did you expect to happen?
for it to successufullly scrap data so I can start using grafana - Can you copy/paste the configuration(s) that you are having problems with?
# SNMP Exporter Configuration File
# Manually created to bypass generator issues.
# Configuration file version.
version: 2
# Authentication and community strings.
auths:
# Default SNMPv1 public community (optional, keep if needed)
public_v1:
version: 1
community: public
# Default SNMPv2c public community (optional, keep if needed)
public_v2:
version: 2
community: public # --- Your Meraki SNMPv2c Authentication ---
# This is the authentication method the exporter will use when 'auth: [meraki_v2c]' is specified.
meraki_v2c:
version: 2
community: 002QWwJxAXqH4WC1cNY6 # <--- **Ensure this is your actual Meraki SNMPv2c community string**
# SNMP modules
# Each module defines a set of OIDs to collect and how to structure the metrics.
modules:
# Standard system information (using numeric OIDs).
# Metrics from SNMPv2-MIB and HOST-RESOURCES-MIB.
system:
walk:
- .1.3.6.1.2.1.1 # system subtree (sysDescr, sysObjectID, sysUpTime, etc.)
- .1.3.6.1.2.1.25.1.1 # hrSystemUptime (Host Resources MIB uptime)
metrics:
- name: snmp_sysDescr
oid: .1.3.6.1.2.1.1.1
type: OctetString
help: A textual description of the entity.
- name: snmp_sysObjectID
oid: .1.3.6.1.2.1.1.2
type: OctetString
help: The vendor's authoritative identification of the network management subsystem contained in the entity.
- name: snmp_sysUpTime_seconds
oid: .1.3.6.1.2.1.1.3
type: counter # Uptime is typically a counter
help: The time (in hundredths of a second) since the network management portion of the system was last re-initialized. Converted to seconds.
transform: "x/100" # Convert hundredths of a second to seconds
- name: snmp_sysContact
oid: .1.3.6.1.2.1.1.4
type: OctetString
help: The textual identification of the contact person for this managed node.
- name: snmp_sysName
oid: .1.3.6.1.2.1.1.5
type: OctetString
help: An administratively-assigned name for this managed node.
- name: snmp_sysLocation
oid: .1.3.6.1.2.1.1.6
type: OctetString
help: The physical location of this node.
- name: snmp_sysServices
oid: .1.3.6.1.2.1.1.7
type: gauge
help: A value which indicates the set of services that this entity primarily offers.
- name: snmp_hrSystemUptime_seconds
oid: .1.3.6.1.2.1.25.1.1
help: The time (in hundredths of a second) since the host system was last initialized. Converted to seconds.
# Standard interface metrics (using numeric OIDs).
# Metrics from IF-MIB.
if_mib:
walk:
- .1.3.6.1.2.1.2.2 # ifTable (contains interface entries)
metrics:
- name: snmp_ifIndex
oid: .1.3.6.1.2.1.2.2.1.1 # ifIndex
type: gauge
help: A unique value, greater than zero, for each interface.
indexes:
- labelname: ifIndex
oid: .1.3.6.1.2.1.2.2.1.1 # ifIndex is both the metric and the index
type: gauge
- name: snmp_ifDescr
oid: .1.3.6.1.2.1.2.2.1.2 # ifDescr
type: OctetString
help: A textual string containing information about the interface.
indexes:
type: gauge
- name: snmp_ifType
oid: .1.3.6.1.2.1.2.2.1.3 # ifType
type: gauge
help: The type of interface.
indexes:
type: gauge
- name: snmp_ifSpeed
oid: .1.3.6.1.2.1.2.2.1.5 # ifSpeed
type: gauge
help: An estimate of the interface's current bandwidth in bits per second.
indexes:
type: gauge
- name: snmp_ifAdminStatus
oid: .1.3.6.1.2.1.2.2.1.7 # ifAdminStatus
type: gauge
help: The desired state of the interface (1=up, 2=down, 3=testing).
indexes:
type: gauge
- name: snmp_ifOperStatus
oid: .1.3.6.1.2.1.2.2.1.8 # ifOperStatus
type: gauge
help: The current operational state of the interface (1=up, 2=down, 3=testing, 4=unknown, 5=dormant, 6=notPresent, 7=lowerLayerDown).
indexes:
type: gauge
- name: snmp_ifInOctets
oid: .1.3.6.1.2.1.2.2.1.10 # ifInOctets (32-bit counter)
type: counter
help: The total number of octets received on the interface.
indexes:
type: gauge
- name: snmp_ifOutOctets
oid: .1.3.6.1.2.1.2.2.1.16 # ifOutOctets (32-bit counter)
type: counter
help: The total number of octets transmitted on the interface.
indexes:
type: gauge
- name: snmp_ifInErrors
oid: .1.3.6.1.2.1.2.2.1.14 # ifInErrors
type: counter
help: The number of inbound packets that contained errors.
indexes:
type: gauge
- name: snmp_ifOutErrors
oid: .1.3.6.1.2.1.2.2.1.20 # ifOutErrors
type: counter
help: The number of outbound packets that could not be transmitted due to errors.
indexes:
type: gauge
# Use ifHCInOctets/ifHCOutOctets if your device supports 64-bit counters
# ifHCInOctets: .1.3.6.1.2.1.31.1.1.1.6
# ifHCOutOctets: .1.3.6.1.2.1.31.1.1.1.10
lookups:
- source_indexes: [ .1.3.6.1.2.1.2.2.1.1 ] # Use ifIndex as the key
lookup: .1.3.6.1.2.1.2.2.1.2 # Look up the ifDescr OID
labelname: ifDescr # Add a label named 'ifDescr'
type: OctetString
lookup: .1.3.6.1.2.1.31.1.1.1.1 # Look up the ifName OID (another common label)
labelname: ifName # Add a label named 'ifName'
type: OctetString
# --- Your Meraki Module Definition (using numeric OIDs) ---
# Metrics from the MERAKI-CLOUD-CONTROLLER-MIB.
meraki:
walk:
- .1.3.6.1.4.1.29671.1.1.4.1:161 # Meraki Device Entry Table, explicitly on port 161
- .1.3.6.1.4.1.29671.1.1.5.1:161 # Meraki Device Interface Table, explicitly on port 161
metrics:
# --- Metrics from the Meraki Device Table (.1.3.6.1.4.1.29671.1.1.4.1) ---
- name: meraki_device_status
oid: .3 # OID relative to the walk OID (.1.3.6.1.4.1.29671.1.1.4.1.3 - devStatus)
type: gauge # Status is a gauge (0=offline, 1=online)
help: Meraki device connection status (0=offline, 1=online).
indexes:
- labelname: dev_mac
oid: .1 # OID relative to the walk OID (.1.3.6.1.4.1.29671.1.1.4.1.1 - devMac)
type: octetstring # MAC address type
- name: meraki_device_client_count
oid: .5 # OID relative to the walk OID (.1.3.6.1.4.1.29671.1.1.4.1.5 - devClientCount)
type: gauge # Client count is a gauge
help: Number of clients currently associated with the Meraki device.
indexes:
type: octetstring
# --- Metrics from the Meraki Device Interface Table (.1.3.6.1.4.1.29671.1.1.5.1) ---
- name: meraki_interface_sent_bytes
oid: .6 # OID relative to the walk OID (.1.3.6.1.4.1.29671.1.1.5.1.6 - devInterfaceSentBytes)
type: counter # Bytes are counters
help: Total number of bytes transmitted on the Meraki interface.
indexes:
- labelname: dev_mac # First index is the device MAC
oid: .1 # OID relative to the walk OID (.1.3.6.1.4.1.29671.1.1.5.1.1 - devInterfaceDevMac)
type: octetstring
- labelname: interface_index # Second index is the interface index
oid: .2 # OID relative to the walk OID (.1.3.6.1.4.1.29671.1.1.5.1.2 - devInterfaceIndex)
type: gauge # Index is a number
- name: meraki_interface_recv_bytes
oid: .7 # OID relative to the walk OID (.1.3.6.1.4.1.29671.1.1.5.1.7 - devInterfaceRecvBytes)
help: Total number of bytes received on the Meraki interface.
indexes:
type: octetstring
type: gauge
lookups:
# --- Lookups for the Device Table ---
# Lookup the device name (devName) using the device MAC index
- source_indexes: [ .1 ] # Source index is the relative OID of devMac from the Device Table walk (.1.3.6.1.4.1.29671.1.1.4.1.1)
lookup: .1.3.6.1.4.1.29671.1.1.4.1.2 # Absolute OID for devName
labelname: dev_name
type: DisplayString
# --- Lookups for the Device Interface Table ---
# Lookup the interface name (devInterfaceName) using the device MAC and interface index
- source_indexes: [ .1, .2 ] # Source indexes are relative OIDs of devInterfaceDevMac (.1) and devInterfaceIndex (.2) from the Interface Table walk
lookup: .1.3.6.1.4.1.29671.1.1.5.1.3 # Absolute OID for devInterfaceName
labelname: interface_name
type: DisplayString
Here is the prometheus config:
global:
scrape_interval: 15s # Default scrape interval
evaluation_interval: 15s # Default evaluation interval
scrape_configs:
# Job for Prometheus itself (good practice for self-monitoring)
- job_name: 'prometheus'
static_configs:
- targets: ['localhost:9090'] # Prometheus runs on port 9090 by default
# Job for Uptime Kuma
- job_name: 'uptime-kuma'
metrics_path: /metrics # Default metrics path for Uptime Kuma [8, 9]
scheme: http # Uptime Kuma metrics are at http://10.101.11.108:3001
static_configs:
- targets: ['10.101.11.108:3001'] # Uptime Kuma IP address and port
basic_auth:
username: 'admin'
password: 'uk2_qUL3AhrpnVNZiWYuy2BwY21n3lzFE8cAAVghdraO' # User-provided credentials
# This goes inside your existing scrape_configs: section
# along with any other jobs you have.
# --- CORRECTED MERAKI JOB STARTS HERE ---
- job_name: 'meraki_exporter_org_367558' # Ensure this '-' is aligned with other job_names
metrics_path: /
params:
target: ['367558'] # Your Organization ID
static_configs:
- targets: ['10.101.11.108:9822'] # IP and port of your Meraki Exporter <--- Removed extra text from here
# Add this job to your scrape_configs section in prometheus.ym
- job_name: 'snmp'
static_configs:
- targets:['10.101.199.2:161'] # The IP of your Meraki device
relabel_configs:
- source_labels: [__address__]
target_label: __param_target
- source_labels: [__param_target]
target_label: instance
- target_label: __address__
replacement: 10.101.11.108:9116 # Replace with the actual IP and port of your SNMP exporter
regex: (.*)
target_label: snmp_target
replacement: $1
- target_label: __param_module
replacement: meraki # The module defined in your snmp.yml
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
NO - Did you follow any online instructions? If so, what is the URL? Gemini got me started but it could finish the job for me
