When I’m trying to start grafana with postgres configuration I’m getting not so clear for me error. This happens with fresh installation. Perhaps someone have any idea what hapeens?
t=2018-12-16T16:13:32+0000 lvl=info msg="App mode production" logger=settings
t=2018-12-16T16:13:32+0000 lvl=info msg="Initializing HTTPServer" logger=server
t=2018-12-16T16:13:32+0000 lvl=info msg="Initializing SqlStore" logger=server
t=2018-12-16T16:13:32+0000 lvl=info msg="Connecting to DB" logger=sqlstore dbtype=postgres
t=2018-12-16T16:13:32+0000 lvl=info msg="Starting DB migration" logger=migrator
t=2018-12-16T16:13:32+0000 lvl=info msg="Executing migration" logger=migrator id="drop index UQE_user_login - v1"
t=2018-12-16T16:13:32+0000 lvl=eror msg="Executing migration failed" logger=migrator id="drop index UQE_user_login - v1" error="pq: index \"UQE_user_login\" is in use as unique constraint (use CASCADE if you really want to drop it)"
t=2018-12-16T16:13:32+0000 lvl=eror msg="Exec failed" logger=migrator error="pq: index \"UQE_user_login\" is in use as unique constraint (use CASCADE if you really want to drop it)" sql="DROP INDEX \"UQE_user_login\""
t=2018-12-16T16:13:32+0000 lvl=eror msg="Server shutdown" logger=server reason="Service init failed: Migration failed err: pq: index \"UQE_user_login\" is in use as unique constraint (use CASCADE if you really want to drop it)"
Cheers,
Flybro
