Grafana version: 8.3.4
OS: Windows 10 -
I am trying to configure reverse proxy for Grafana using Spring Cloud Gateway. -
I have read through the Run Grafana through a reverse proxy article on the Grafana docs and updated my custom.ini file with the following:
root_url =
serve_from_sub_path = true
I have also added the following static route in my Spring Cloud Gateway application.yml file:
# Static routes
routes:
# Redirect to Grafana
- id: grafana
uri: http://localhost:3000
predicates:
- Path=/grafana**
filters:
- RewritePath=/grafana/(?<remaining>.+), /$\{remaining}
What happened?
When accessing Grafana through the reverse proxy URL the login page for Grafana successfully loads however when entering my login details for grafana a message appears on screen “Invalid CSRF Token” and I get a 403 Forbidden response. I tried accessing Grafana without the reverse proxy enabled through localhost:3000 with the same credentials and was able to login successfully. -
I expected to be able to login into Grafana via the reverse proxy. Is there something in the Grafana configuration I am missing that may solve this? -
In the Grafana logs I can see this message. I’m not sure if it indicates the problem:
“Validated license token” logger=licensing appURL=http://localhost:8080/grafana/ source=disk status=NotFound
