Hi Iam using the latest version of the Grafana’s docker image and I want to connect my sentry to my Grafana and I get this error when clicking on save and test button.
invalid character '<' looking for beginning of value
here is my question. in the sentry integration page what I should insert for the Webhook URL
and where is the Sentry Auth Token? I think this error occurs because of these two values.
I have not used the Sentry plugin, however I found its page where it describe some steps as how to configure the Data source (including the Auth part).
Please have a look as it might bring you one step closer?
Hi @usman.ahmad. Thanks for your reply. I’ve seen this before but when I did this guide step by step, the result was the same.
Hello, I met the same issue, do you resolve this issue? I use different grafana verision, still has the same issue.
