We have tests run under different names, but want to compare test results, how to compare test results which are run under 2 different test names. Attached snapshot for reference. In below snapshot how to compare tests from 2 different sprints.
Thanks,
Huligesh
Hi @huligesh.hanumanthap,
as mentioned in test comparison documentation, this use case isn’t supported. We are going to track your feature request and maybe we will support it in future.
However, you can use the Grafana Plugin to import your test results then you will be able to query the result data across different tests for comparing them.
