Hi, here’s my problem: I got data from a DB in MS SQL Server and when I use the dropdown list that I created, the colors in the bar graph that I want to display don’t update according to the values. Here is my panel when I refreshed the page. The second image is when I changed the “Résine” in my dropdown list, the colors are staying like they were and don’t update (values 17.3 should all be the same color.)
I used the color scheme Red-Yellow-Green (by values) and I also tried to add a field override to see if the problem would be solved, without success.
I can’t find any information about that problem. Thanks.
