I have a docker compose file with application containers and one container each for Prometheus, Loki, Zipkin and Grafana.
I am trying to code a derived field of type Internal Link in the datasources.yaml file mounted in the Grafana container. But the below snippet doesn’t seem to work. The Grafana UI does not show this derived field as an internal link (internal link toggle is disabled).
apiVersion: 1
datasources:
- name: Zipkin
type: zipkin
access: proxy
url: http://zipkin:9411
editable: true
- name: Prometheus
type: prometheus
access: proxy
url: http://prometheus:9090
editable: true
- name: Loki
type: loki
access: proxy
url: http://loki:3100
editable: true
isDefault: true
jsonData:
derivedFields:
- datasourceName: Zipkin
matcherRegex: "\\[.*,(\\w+),.*,.*\\]"
url: "${__value.raw}"
https://grafana.com/docs/grafana/latest/features/datasources/loki/ has an example snippet, but that uses “datasourceUid”. I doubt that the datasourceUid is available during design time.
What am I missing?
Also, I am able to get the internal link working using the Grafana UI. Is there a way to export the datasources.yaml from a running Grafana instance?
Thanks for your help.
cheers,
senthil
Please, check out this github issue to see more information/guidance on how to set this up:
