Is it possible to deploy Alloy as a cluster on ECS instead of a Kubernetes? It’s not clear on the docs.
Reference: Configure Grafana Alloy clustering in an existing installation | Grafana Alloy documentation
Thank you.
Thank you.
Yes, it can be done. There are two ways you can achieve this:
AWSVPC mode (so that each container has a unique IP), then create a Cloud Map service discovery record and make sure it’s A record. Then you can cluster your Alloy containers like so:command = [
"run",
"--cluster.enabled=true",
"--cluster.join-addresses=${service_discovery_a_record_name}",
"--cluster.max-join-peers=0",
"--cluster.name=${alloy_cluster_id}",
"--server.http.listen-addr=0.0.0.0:${alloy_http_listen_port}",
"--storage.path=${...}",
"${config_path}/config.alloy"
Do note Cloud Map returns up to 8 DNS records, so you can at most run 8 Alloy containers in your cluster.
