I deployed Alloy instances in Azure AKS behind a local load balancer, and here is my Terraform configuration:
resource "kubernetes_manifest" "alloy" {
# depends_on = [kubernetes_secret.tls_cert_secret]
manifest = {
apiVersion = "collectors.grafana.com/v1alpha1"
kind = "Alloy"
metadata = {
name = "alloy"
namespace = data.kubernetes_namespace.alloy_namespace.metadata[0].name
spec = {
controller = {
type = "daemonset"
service = {
enabled = true
type = "ClusterIP"
internalTrafficPolicy = "Local"
alloy = {
clustering = {
enabled = true
configMap = {
create = false
name = var.alloy_config_name
uiPathPrefix = "/"
extraPorts = [
name = "log-udp"
port = 514
targetPort = 514
protocol = "UDP"
extraArgs = [
"--feature.community-components.enabled=true",
"--stability.level=experimental"
ingress = {
enabled = true
faroPort = 12345 #
path = "/"
ingressClassName = "nginx"
hosts = [local.ingress_host]
“As you can see, clustering is enabled and I have two participants in the Alloy cluster.
I’m performing SNMP polling with this conf :
prometheus.exporter.snmp "default" {
config = local.file.default.content
targets = discovery.relabel.snmp_default.output
prometheus.scrape "default" {
targets = prometheus.exporter.snmp.default.targets
scrape_timeout = "30s"
scrape_interval = "300s"
clustering {
enabled = true
forward_to = [prometheus.relabel.default.receiver]
The problem is that only the participant with Local Node checked is scraping, so only a subset of my SNMP targets are being scraped.
